Axle Replacement Question
Posted: Fri May 21, 2004 2:45 am
by 123c
Would it be better for me to spend $106.64 at Subaruparts.com, or $72.93 at another online parts store for an Axle. If I am going to get a better quality part at Subaruparts.com, then I might spend the extra money...
Posted: Fri May 21, 2004 3:22 am
by mTk
I personally would get the axle from one of the places that have a lifetime warranty. That way at least you never have to pay for a replacement axle. Napa and auto zone etc have 'em
MK
Posted: Fri May 21, 2004 4:43 am
by 123c
I'm going to get the Genuine rebuilt axle from Subaruparts.com it looks like.
Before I order one, what are some of the other parts I should be replacing when I am replacing an axle, so I can order those at the same time...
Posted: Fri May 21, 2004 4:53 am
by eastbaysubaru
Make sure it comes with a new axle nut and a spring pin. They didn't come with my new axles
Part numbers 28044AA000 and 051906452 respectively.
-Brian
Posted: Fri May 21, 2004 5:10 am
by 123c
eastbaysubaru wrote:Make sure it comes with a new axle nut and a spring pin. They didn't come with my new axles
-Brian
So I need one per axle?
Isn't there a seal or two that I should replace while I have things apart?
Posted: Fri May 21, 2004 5:27 am
by eastbaysubaru
Yup, you'll need both of 'em for each side. Two axles nuts and two spring pins. Not too sure about the seals though. I didn't replace anything.
-Brian
Posted: Fri May 21, 2004 7:13 am
by 123c
The Axle is actually $41, with a $65 core charge,
I will go ahead and order the parts now, and if anyone has anything to add, such as seals, I will order those later...
Posted: Fri May 21, 2004 2:20 pm
Posted: Fri May 21, 2004 4:32 pm
by eastbaysubaru
I'll second that place although shipping was a bitch getting those things back to Florida. They also didn't give me new axle nuts and spring pins.
-Brian
Posted: Fri May 21, 2004 4:41 pm
by nubs
Go to Napa. The ones I got from there came with a new nut and spring pin. Lifetime warranty also. I think they were around 50 bucks each.
Posted: Fri May 21, 2004 5:53 pm
eastbaysubaru wrote:I'll second that place although shipping was a bitch getting those things back to Florida. They also didn't give me new axle nuts and spring pins.
-Brian
Shipping via fedex ground wasn't bad......and you have to ask for new axle nuts & roll pins.....
Posted: Fri May 21, 2004 11:20 pm
by eastbaysubaru
Ahhh...I probably should've asked
-Brian
Posted: Sat May 22, 2004 3:39 am
by entirelyturbo
cvaxles.com is the best...
ciper has a tough time breaking their axles, which means they should last quite a while in anyone else's car
Both my Scoobs have their front axles from them.
