ALL WARNING LIGHTS ON?
Posted: Mon Jun 07, 2004 5:45 am
by Legacytuner
when i got my silver bullet out of storage and started it up the brake,abs,battery,stop lamp,lights came on its been acouple of days and they are still on i put new pads and rotors all the way around before storage and the battery is brand new and the brake lights work fine i cant figure out why they are on. has anyone had this problem before :(
Posted: Mon Jun 07, 2004 2:02 pm
I'd be suspicious of the alternator. may want to have it tested.
Posted: Mon Jun 07, 2004 4:16 pm
by nubs
Legacy777 wrote:I'd be suspicious of the alternator. may want to have it tested.
I had this problem on my SVX along with other owners. Like 777 said,it could be a bad alternator. I would start with cleaning up the altenator connections. That is what took care of the problem on my car. If that does not work it is most likely the alternator going bad.
Posted: Mon Jun 07, 2004 8:32 pm
by petridish38
Take the alternator to an auto parts store and have them test it. Most likely it will be bad.
Andrew
Posted: Tue Jun 08, 2004 2:50 am
by stant093
what about pulling the battery terminals off the battery while its running, i heard thats a way to quickly test the alternator...
Posted: Tue Jun 08, 2004 3:23 am
by evolutionmovement
Use a meter. The battery's part of the circuit so either way it should kill the car to remove it. Am I wrong? I know older cars were wired in series.
Posted: Tue Jun 08, 2004 2:23 pm
No....don't ever remove the battery while the car is running......that's a good way to fry things.
The battery acts as a sink and filter to help smooth out the voltage spikes coming from the alternator. Remove it....and you lose that smoothing affect with the voltage.
Take the car to an autoparts store and have them test the alternator. SIMPLE!
I will however caution you that sometimes they may still show marginal or good when in the car. If you want a true test....take it out of the car and bring it into the store for them to test.
Posted: Fri Jun 11, 2004 12:59 am
by Legacytuner
:lol: thanks all, it was the alternator :lol:
