I am debating whether I should smooth out some of the passages in the heads while they are off. I'm not looking to remove a lot of material because I don't want to eat into a coolant passage. I was going to use a dremel and remove some of the casting and rough areas.
Is it worth my time since I'm not really "port" the heads? Bad idea?
Porting heads?
Porting heads?
92 Turbo Legacy 4EAT
02 WRX - lightly modded (Gone but not forgotten)
there is a lot of meat in there to port at, get the factory gasket and port that much away you will be fine, and have a fast car when your done.
from porting a head gives about the same HP gain as a set of headers, which isn't much at all, but if its going to cost nothing then I say go for it. about a 10WHP gain can be expected.
