Forester Trouble
Posted: Fri Nov 19, 2004 1:44 am
by J-MoNeY
My moms 99 Forester is having acceration issues. I have changed the plugs, fuel filter, and filter. I haven't tryed anything and I'm all out of ideas.
Problem: When you step on the gas, the car goes no where. It feels like a lurch then promtly feels like it is going to die, then all of a sudden picks up and drives fine. I'm not sure what the problem could be. Any help would be appreciated!
Posted: Fri Nov 19, 2004 1:46 am
Is it an automatic? Maybe it's a transmission issue.
Posted: Fri Nov 19, 2004 1:52 am
by totech
Try resetting the ECU. The modern cars really lean out the mixture at idle, and resetting it should help you troubleshoot.
I have had trouble with front o2's too, similar symptoms.
Posted: Fri Nov 19, 2004 7:28 am
by tris91ricer
yeah.. that whole stomping the gas and going nowhere thing sounds REALLY familiar now.. could be the tranny.. what's it been through? have there been recalls on that at all?
Posted: Fri Nov 19, 2004 8:37 am
by J-MoNeY
It's been on a lot of trips but that's about it. It is an Auto. Think the TCU ought to do it?
Posted: Fri Nov 19, 2004 9:01 am
by BAC5.2
Most importantly, do the revs jump when you hop on the gas?
If not, then it's likely a TCU problem.
If so, then you can pretty much be assured that the tranny is at fault.
Posted: Fri Nov 19, 2004 9:14 pm
by J-MoNeY
BAC5.2 wrote:Most importantly, do the revs jump when you hop on the gas?
Not really. You romp on it and it feels like the car is about to die and the rpms dip into the low hundreds.
Posted: Fri Nov 19, 2004 9:37 pm
by tris91ricer
mm... IAC, perhaps?
is there a way to pull the codes on that car.. They're new, so i have no idea how those ones work.. can't you get it to a CSK, or something and have 'em use the scantool for free?
Posted: Fri Nov 19, 2004 11:17 pm
by J-MoNeY
It doesn't pull code or else the CEL would be on, right? :-\
Posted: Fri Nov 19, 2004 11:51 pm
by tris91ricer
oh, true, true!
hmm.. that's new...
