engine identification
Posted: Tue Jan 04, 2005 12:55 pm
by vw_speedsterke
I have here an engine, probably from a legacy. the numbers which I find, its ej20 and 640619. The engine is a 4cams en with turbo. but see only ej20 standing and not ej20t!
can someone tell me of which year this engine is?
Posted: Tue Jan 04, 2005 2:56 pm
by IronMonkeyL255
Normally, the identification on the block will only say EJ20.
My EJ22t only says EJ22 at the front (down on the block b/w the p/s pump and alternator).
Hope that helps a bit.
Posted: Tue Jan 04, 2005 7:45 pm
by 91White-T
If it has the AWIC its an EJ20G from a 89-92 legacy. If not its from a WRX.
Posted: Tue Jan 04, 2005 11:06 pm
by vw_speedsterke
91White-T wrote:If it has the AWIC its an EJ20G from a 89-92 legacy. If not its from a WRX.
what means you with AWIC?
Posted: Tue Jan 04, 2005 11:22 pm
by 91White-T
Air/water intercooler. Black or silver box in front of the throttle body that says "Turbo Intercooler" or something of that sort.
Posted: Tue Jan 04, 2005 11:50 pm
by vw_speedsterke
91White-T wrote:Air/water intercooler. Black or silver box in front of the throttle body that says "Turbo Intercooler" or something of that sort.
yes i have a black box with "turbo intercooler". how know you that is it of this type legacy? by the type of number of this engine?
Posted: Wed Jan 05, 2005 12:47 am
by 91White-T
89-92 non USDM legacys (BC5/BF5) came with the air water IC and ej20g quad cam, so that is almost certainly what chassis its from.
Posted: Wed Jan 05, 2005 11:40 am
by vw_speedsterke
can I assemble the cylinder heads of a my98 on this engine?
Posted: Thu Jan 06, 2005 3:00 am
by Matt Monson
vw_speedsterke wrote:can I assemble the cylinder heads of a my98 on this engine?
You can but it would be a step backwards. For starters you would greatly reduce the flow. Old does not mean bad. The EJ20G (That is what you have) heads flow much better than the EJ254 DOHC heads.
And then there is a whole combustion chamber volume issue. The EJ20G combustion chamber is 57cc and has a CR of 8.5:1 Putting the 47cc EJ254 heads on there would send you up over 9:1. If you wanna boost it, keep the stock heads.
If it ain't broke don't fix it...
Posted: Sun May 08, 2005 9:07 am
by Project_Legacy
hmm i have a couple questions on this.
what are the specs on the ej20g??
the ej20 that ive been lookin at has tags that says BF5 which would be a wagon?? the mechanic says its an ej20T from a 95 JDM WRX. it has the air to water intercooler on it, DOHC heads, he says it has a TD-05, and all the writing on it says ej20T.
another question, are the ej20t and ej20g fuel injectors the same color? if they arent, what are the colors? the motor i saw looks like it has gray injectors.
anyway thanks for any help.
Don
Posted: Sun May 08, 2005 4:05 pm
by 91White-T
BF5 means it came from a legacy wagon, the td05 is probably from a wrx though.
Posted: Sun May 08, 2005 6:01 pm
by THAWA
There's no engine called an EJ20T.
Posted: Sun May 08, 2005 11:47 pm
by Project_Legacy
i heard the wagons had the smaller td-04 though. and these motors look all stock. im pretty sure they are as well. they have all the stock exhaust piping with turbo chimney's as well. so im a bit confused... this mechanic said it came from a sedan. maybe that BF5 meant something else... not sure. but thanks for the replies guys.
anyway i have another question, i'm going to be hybriding that motor with ej22t heads, intake manifold, fuel rails, etc. basically i will just be using the shortblock of the ej20t. has anyone ever done this? i will be doing that so i can use the electronics of the ej22t as i already have those. anyway thanks a lot for any help. i dont know much about these ej20's.... thanks!
Don
