Difference in fuel lines?
Posted: Tue Jan 11, 2005 7:46 pm
by IronMonkeyL255
I was planning on replacing most of my fuel lines when I do the pump and filter.
What is the difference between regular fuel line and fuel injection line (besides $4/ft)?
The local Autozone was out of the regular stuff and only had the fuel injection stuff.
Are our lines just 5/16?
Posted: Tue Jan 11, 2005 9:05 pm
by tris91ricer
Yes, 5/16th is correct. However, looking at my lines the other day, I noticed that not all of them are the same size.. check to make sure they're all 5/16th, and not 5/16ths with a couple 3/8ths, thrown in there.. I dunno.
Posted: Tue Jan 11, 2005 11:29 pm
Our stock fuel hoses are 7.5mm. 5/16" fits pretty closely though.
Regular fuel hose is not meant for the relatively high pressures seen in MPFI systems. Fuel injection hose is. Obviously, then, you should get fuel injection hose, unless you relish carbeque.
Also, if you're changing any of the hose clamps, be sure to replace them with fuel injection clamps, not regular worm-drive clamps or -- God forbid -- spring-type clamps. If you look at your stock clamps you'll see that they're much kinder to the hoses than worm-drive clamps, which helps make sure the hoses stay intact.
Posted: Wed Jan 12, 2005 6:13 am
by tris91ricer
vrg3 wrote:Our stock fuel hoses are 7.5mm. 5/16" fits pretty closely though.
huh?
Posted: Wed Jan 12, 2005 6:15 am
Hm?
What part was unclear?
Posted: Wed Jan 12, 2005 11:44 am
by IronMonkeyL255
What do these fuel injection clamps look like?
I had heard that the worm clamps are the best, as they most evenly spread the force around the hose.
Posted: Wed Jan 12, 2005 3:46 pm
worm clamps eat the hell out of hoses.....
Posted: Wed Jan 12, 2005 6:06 pm
by IronMonkeyL255
true.....
Posted: Thu Jan 13, 2005 3:11 am
A fuel injection clamp spreads the force evenly as well, but lowers the risk of damaging the hose:
http://www.graphics.cornell.edu/~v/pics ... _clamp.jpg
Posted: Thu Jan 13, 2005 9:03 pm
by IronMonkeyL255
That's what I thought.....
