ah crap
Posted: Fri Feb 25, 2005 12:59 am
my engine is accelerating without me
ive got something wrong with my idle.
when im at stops the engine is at 1.5 RPM while in D.
In N it went up to 2 RPM then slowly back down to 1-1.5 RPM
when I got home and pushed on the accelerator in the engine bay a little bit to check to see if it was throttle plate related, it finally slowly went back down to a normal idle.
Any guesses for whats wrong?? TPS, ECU, Timing belts???
