hello all
Posted: Sat Feb 26, 2005 5:30 am
by Mackenzie
hey, new to the site, new to subarus. and i found a awd turbo legacy that i might get. and i was wondering if the aftermarket makes parts for these cars? or are most of the performance mods you guys go homemade? and these cars can be made fast right? im sure the turbo motor has potential. and what are the specs on the car? motor tranny, etc???
Posted: Sat Feb 26, 2005 8:01 am
by dzx
Well welcome to legacy central, there are some aftermarket turbos available for the legacy but not many other aftermarket parts. Some people go with wrx intercoolers that require a little massaging of the firewall with a hammer. The cars can be made fast but it takes a little money unless your good at bargain hunting. I dunno what you want by specs.
Posted: Sat Feb 26, 2005 1:43 pm
by G-reg
You can raid the Suby parts bin for quite a lot of stuff, and you can use aftermarket parts for other Suby's pretty easliy.
Posted: Sat Feb 26, 2005 5:20 pm
by Mackenzie
specs like hp, liters, sohc or dohc, etc. so some wrx parts fit. what about intake and exhaust, or basic bolt ons in general?
Posted: Sat Feb 26, 2005 5:25 pm
by Mackenzie
and can you guys give me some sites with info and parts for the SS legacy?
Posted: Sat Feb 26, 2005 5:49 pm
by Subaru_Nation555
Welcome!
In terms of specs. legacycentral.org has all of that info in the library section I believe. As some people have mentioned earlier, many other Subaru parts fit onto the Legacy including but not limited to: downpipes, brakes, wheels, struts, springs, strut braces, intercoolers, turbochargers and some interior pieces. As far as I know there are no intakes made for 91-94 Legacy SS but custom parts can always be made.
In terms of an exhaust, most any WRX downpipe will bolt onto the existing turbo, but a custom midpipe and muffler need to be added too. All in all its generally not more expensive then an aftermarket exhaust a WRX owner might buy. There is a company whose name has slipped my mind, that makes a beautiful turbo-back exhaust specially for the SS but its pricey, some members here are running it. Check out legacycentral or read around here some for specs.
Posted: Sun Feb 27, 2005 12:42 am
by legacy92ej22t
The above mentioned TBE is the C.E.S. Racing system and they are absolutely amazing. They are also expensive. A full stainless steel system will run between $1,100 and $1,800 depending on the system. I for one think they're worth it.
Most suspension parts are interchangeable. Pulleys, drivetrain (clutch, flywheel) from the WRX can be swapped over, tranny and engine mounts, turbos, wheels, ect.. There's really quite a bit out there that'll work with our cars but some of it just takes a little massaging to work.
They're great cars, buy it, you won't be sorry.
Posted: Sun Feb 27, 2005 7:16 pm
by Mackenzie
i see. so how fast are these cars when they are modded? i see one guy had in his sig that he had 251 wheel torque thats crazy. ill call the guy today or tomorrow bout the car. i dont think no one knows about these cars. so he might not sell anytime soon.
Posted: Mon Feb 28, 2005 2:16 am
by LaureltheQueen
That's phil, he's dumped ALOT of money into his turbo, but it's definitely a good alternative to a wrx.
as far as specs.
www.edmunds.com
do searches, you'll find all the information you're looking for
