A/F meter fluctuations
Posted: Sun Apr 17, 2005 7:24 am
by Binford
I just got my gauge pod mounted with my boost and A/F gauges hooked up. I tapped onto the white wire on the O2 sensor for signal. In doing so I found the wire had pulled out of the connecter about a quarter inch. I pushed it back in, but the A/F guage totally freaks out while driving. How much is it supposed to fluctuate?
Posted: Sun Apr 17, 2005 4:23 pm
by 91White-T
A lot. An A/F gage is really for show more than anything. As long as it goes full rich when you go WOT, then its working right. Other than that it will just jump back and forth non-stop.
Posted: Wed Apr 27, 2005 5:47 am
by azn2nr
[hijack] which wire do you tap into for signal anyways[/hijack]
i just got my gauge and need to install it
Posted: Wed Apr 27, 2005 2:47 pm
by 91White-T
Red on the O2 harness I believe. Check your haynes manual to make sure though.
Posted: Wed Apr 27, 2005 3:10 pm
by dzx
If you want one for function get a wideband O2. I've got the one that jumps around and it gets kinda annoying. It does give you a general idea of whats going on with the engine tho.
Posted: Wed Apr 27, 2005 6:33 pm
by azn2nr
cool.
i know its gonna get anoying.
i bought it to fill a hole so fill it will
