Who can figure this one out?
Posted: Wed May 04, 2005 5:00 pm
by Tleg93
I have a friend (no, it's not me) who has an L with a stubborn overheating problem that no mechanic has been able to trouble shoot as of yet.
Here's what's been done so far:
He replaced the radiator with a new one.
He replaced the water pump.
He put in all new hoses.
He got a new radiator cap.
He replaced the thermostat.
Some symptoms and info
At one point he found metal in the oil and it turned out to be from the water pump apparently.
It does fine on idle, overheats on the highway.
It's odd that it overheats on the highway because I'd think that the air would keep it cool. Usually you'll get overheating when you stop. They've basically replaced his entire cooling system except the fan.
Posted: Wed May 04, 2005 5:02 pm
by tris91ricer
..and the fans are coming on, right? Otherwise, I'd look at maybe the fans being the culprit...?
Posted: Wed May 04, 2005 5:03 pm
Metal in the oil? The water pump doesn't come in contact with the oil....?
Is it an OEM thermostat?
Has the system been properly bled of air?
If everything else is fine, I'd lean towards head gaskets.
Posted: Wed May 04, 2005 5:06 pm
Is it plausible that cooling passages (either in the water manifold or in the motor itself) are clogged? Has the system been power flushed or anything?
Did they check the coolant for exhaust gas? It could potentially be something like a leaking head gasket, right?
Is the water pump lubricated by motor oil? I thought its bearing was sealed.
by Tleg93
My bad, isn't wasn't metal in the oil. They found metal when they drained the coolant. He was told the heads were in good shape. No frothy oil and no noticeable leaks.
Posted: Wed May 04, 2005 5:08 pm
Unless they do a test for hydrocarbons in the coolant and it comes back negative, I wouldn't rule out the head gaskets. Other possibility is a crack in the head or block.
Posted: Wed May 04, 2005 5:09 pm
by Tleg93
vrg3 wrote:Is it plausible that cooling passages (either in the water manifold or in the motor itself) are clogged? Has the system been power flushed or anything?
I guess they pumped coolant through the system and tested for leaks.
Posted: Wed May 04, 2005 5:13 pm
Hmm... If chunks of water pump got into the coolant, it does seem plausible that some could still be in the system somewhere... And if they block flow enough, couldn't that cause the water pump to cavitate at higher speeds?
Posted: Wed May 04, 2005 5:24 pm
by J-MoNeY
It's the headgaskets. The coolant will not be milky always. Replace those and I'd bet you the problem goes away.
Posted: Wed May 04, 2005 6:48 pm
by dzx
I'd check the spark plugs for the hell of it. My mom's car overheated several times in omaha and we found out it was just a loose spark plug, might have been all the way out, i cant remember as it was years ago.
