Interesting result of low compression, no further detonation
Posted: Thu May 05, 2005 3:22 am
OK, I havent actually compression tested the cylinders yet but since the bad night at the track, and all the xtra oil coming in throught the crankcase breather lines, I am pretty darned sure I damaged something somewhere. Also, I have less power (not sure HOW much less, just less) off boost, and presumably less while on boost.
However, I still have plenty of power when on boost. And most importanly, the motor hasn't had a single instance of knock since then.
So lets say I broke a ringland or something, which allows some compression loss in the piston(s) that were susceptable to detonation. Is this similar to lower compression pistons IF the damage remains static?
I will rebuild eventually, but since I don't have the money right now, I might as well keep running it until something serios happens (I have an extra block and extra engine if something horribly catastrophic were to happen to the actual block). I will be running it in the next rallycross for sure.
If it stands up to the abuse from the rallycross without damage AND more importantly, knock, I will spring for the next larger pulley I can install and attempt the 10 plus psi I have been trying for for so long.
