Oil Leak...
Posted: Thu May 19, 2005 5:39 pm
by nsantos23
i got a weird oil leak, its coming from the timing belt cover! i'm assuming that is from the front seals? well i'm due for a TB change at 90K miles so i'll just get it changed too, how hard is to change them?
Neo
Posted: Thu May 19, 2005 10:13 pm
by irishsetter
Not to bad I did my cam seals, crank seal, and new water pump in about six hours. Take out the radiator and everything on the front then make sure when you take off the crank and cam pulleys do not spin them with the timing belt off and never turn the engine backwards. All together it is easy.
