Lube the door?
Posted: Fri May 27, 2005 12:19 am
by Bosco
My door has a stiffy.
Er.. um... I mean...
My passenger door is stiff and somewhat difficult to close.
It takes easily 3 times the effort to close as the driver's door.
Any suggestions for lubricants I should use (or NOT use)
I'm sure I'll try to lube everything that moves in there.
Hee... I said stiffy... and lube.
Posted: Fri May 27, 2005 4:51 am
by LaureltheQueen
try silicone lubricant. you can pick it up in a spray can in the chemical section of your local auto parts store(cskauto)
