Adjustable FPR
Posted: Thu Jul 14, 2005 3:10 am
I've searched around on here, and a tad on nasioc. Aeromotive seems to be the "shit" type adj. fpr, but I wanted to see if anyone else has any suggestions.
Posted: Sun Jul 17, 2005 6:33 am
The OEM FPR used on certain cars with Bosch D-Jetronic EFI systems is adjustable from the factory. But, it's atmosphere-referenced, not manifold-referenced.
It's not hard, however, to modify it to make it manifold-referenced. You basically turn the adjustment screw into an air channel (like a banjo bolt, sort of) and attach a pressure port to the end. MSD does it and sells it as their part number 2222, which Summit Racing sells for 60 bucks:
http://store.summitracing.com/default.a ... MSD%2D2222
Dune-Buggy.com has instructions for doing it yourself:
http://www.dune-buggy.com/turbo/fuelsystem.htm
The Bosch regulator's inlet and outlet nipples fit our stock hoses well.
Posted: Wed Jul 20, 2005 3:17 am
So if I bought the MSD one, I would not have to modify anything, correct?
I'll take a look at the dune buggy page.
thanks
Posted: Wed Jul 20, 2005 4:02 am
Yes, I believe that is correct. You wouldn't even have to remove your stock FPR if you just wanted to raise fuel pressure; you could just stick the MSD one in the return line.
Hm, but I just realized -- that maximum pressure setting on that FPR is only 45 psi, which isn't very high.
Posted: Wed Jul 20, 2005 4:36 am
by NICO
vrg3 that fpr wont fit in the stock rials at all, its to small.
Posted: Wed Jul 20, 2005 5:00 am
It'll fit the stock hoses, not the rail.
Posted: Wed Jul 20, 2005 5:34 am
I'm completely redoing the fuel lines. Going to do the parallel fuel mod. I will be removing the stock regulator completely, and will be using two driver's side rails.
Posted: Wed Jul 20, 2005 3:55 pm
by JasonGrahn
aeromotive is the shit. also has dual inlets for those running that parallel fuel mod.
Posted: Thu Jul 21, 2005 1:38 am
dual inlets from the tank, or dual outlets to the lines?
Posted: Thu Jul 21, 2005 1:42 am
FPRs have inlets from the rail(s) and outlets to the tank(s).
Posted: Tue Aug 09, 2005 2:57 am
I've decided not to bother with the series to parallel mod right now.
I talked with Dale at Teague's for a little bit this morning, and from his experience they haven't really run across fuel starvation, assuming you have a good pump like the walbro.
I may revisit it when I put bigger injectors & a larger turbo on, but for now, I'll just save the hassle.
Posted: Tue Aug 09, 2005 9:30 am
by NICO
i would not even think of changeing them, perfect made.
