Pinging at max booste any ideas
Posted: Fri Aug 05, 2005 4:07 am
by Calgaryturbo
92 octane and lately the car is pinging when under load. I think the fuel system is fine but I don't have a walboro pump. Maxing out at 10 psi of booste with no intercooler
Wondering if wires could be the problem. I have had some NGK blue wires in there for about 100 000Km. Do they wear out?
Re: Pinging at max booste any ideas
Posted: Fri Aug 05, 2005 5:03 am
by 91White-T
Calgaryturbo wrote:no intercooler
There's your problem.
Posted: Fri Aug 05, 2005 5:20 am
by Psychoreo
i agree, any time you run anything above the stock boost regs, you bassically have to use an I/C. Check the intercooler forums and you should find your solution there.
Posted: Fri Aug 05, 2005 5:41 am
by Calgaryturbo
I have been running the car like this for a while now and it never used to ping. When I say max boost is 10 I mean it sometimes spikes to 10. Normally full boost is around 7-8 and it still pings.
Posted: Fri Aug 05, 2005 7:02 am
by douglas vincent
Changed gas lately? Running premium?
CHECK your plugs and wires. Make sure the plug wires are secure.
Posted: Fri Aug 05, 2005 4:35 pm
by Calgaryturbo
Ya i will get new wires today. I always run premium and the plugs are new. I hear our cars go through wires and mine are 3 years old>
Posted: Fri Aug 05, 2005 5:22 pm
by Calgaryturbo
spoke to the stealership because no one has wires for my car and they said that wires wouldn't cause pinging.
Also I do have a newer knock sensor. What if my fuel pump doesn't have enough pressure. I did replace it once but with a cheap one.
I will start looking for an intercooler!!!
Posted: Fri Aug 05, 2005 7:46 pm
by Calgaryturbo
just checked the resistance of the wires and coil and they are fine. I am going to pull my injectors and have a look at them. Maybe soak them in injection cleaner. I am thinking my problem is fuel now. Also found an intercooler from a saab 900 for 100$ at a wreckers. I will turn the boost right down until the pinging is gone I guess. Any other ideas what might be the problem. It is pretty hot here right now also.
