Check Engine Light
Posted: Wed Aug 10, 2005 2:49 am
by Legacypusher
I have been under the dash of my '90 Legacy trying to find the leads to connect to read my Check Engine Light codes with no success. I would appreciate some help for exactly what to look for. The old gal has only 146K on her, and runs like a top. I think I'll keep her.
Posted: Wed Aug 10, 2005 2:52 am
Do you have an AT or MT?
If you have an auto trans, you may need to loosen the two bolts holding on the trans computer to find the connectors. I had to.
This pic might help.
http://www.main.experiencetherave.com:8 ... cuhide.jpg
Posted: Wed Aug 10, 2005 3:00 am
by Legacypusher
Wow, thanks for the quick response. I have a five speed, FWD wagon. I tried the green connectors, which were the only ones I could find that matched, and got some very interesting sounds, but no help on the flashing engine codes. I appreciate your help.
Posted: Thu Aug 11, 2005 7:07 pm
by Project_Legacy
i believe its the black single-wire connectors. the green ones are used for a different kind of check.
Posted: Thu Aug 11, 2005 9:53 pm
by Legacypusher
Thanks for the response. I removed the access panel and finally found the black connectors. They were pretty well hidden. Will proceed from there. I haven't noticed any performance or gas mileage problems, but the CEL is annoying.
This is a great forum--I've been scouting around and have found answers to many of my questions.
Posted: Fri Aug 12, 2005 7:58 am
by Project_Legacy
heh if everything still seems fine it might just be the purge canister solenoid code. its code 35. although when mine had that it gave me a pretty low idle but thats about it. its nothing too big to worry about i believe.
i have no idea why no one else had responded to your question. maybe they wanted you to search. iunno.
