Starting/lugging issues
Posted: Wed Aug 10, 2005 8:46 am
I have a 1993 Legacy, and I am having a problem with my car when i start it.
It wont start a lot of the time and when I pump the gas while cranking it sometimes I can get it to start.
Also, when I drive it, it lugs sometimes in 1st gear and other times it will do it 1-3 gears. Kind of like if i were to push on and off the gas, so it bounces sort of.
It is the 1993 Legacy with the turbo.
I was thinking maybe the fuel filter might be needing a change, or perhaps its the injectors or fuel pump. Im not sure its the injectors because i ran some cleaner through the tank... but I'm not sure.
I'm wondering if there are any known problems/issues with this particular year/generation of Legacy because it is the first year of its generation correct?
Any help would be most appreciated.
Regards,
-Tyler
Regards,
-Tyler
