Combing through engine specs
Posted: Tue Aug 30, 2005 10:56 pm
I just got a program called Dyno2003 which runs a 'virtual' Dyno of your car, i.e. it creates a simulation of engine dynamics and estimates the torque/hp. My friend uses it to get an estimation of the payoff of certain mods before actually laying down the cash and the time. It's not 100% accurate, but it gives you a decent idea.
You need to give it a ton of information, and I've found some of it, but there are still lots of gaps. Hopefully you guys can help fill them in, and correct errors
The car is a 92 Sport Sedan
Shortblock
Cylinders: 4
Bore: 96.9mm
Stroke: 75.00mm
Cylinder Volume: 553.00cc
Total Volume: 2212.37cc
Cylinder Heads
Intake Valves: 2
Intake Valve Diameter: 1.420in
Exhaust Valves: 2
Exhaust Valve Diameter: 1.240in
Compression
Compression Ratio: 8.00:1
Combustion Space: 79.01cc
Induction
Induction Flow: ? cfm @ ? inHg
Manifold Type: Forced Induction?
Forced Induction Specifications
Blower Type: Custom Turbo (it doesnt have ours listed)
Island Flow:
Impeller Speed:
Peak Efficiency:
Surge Flow:
Belt Ratio:
Boost Limit: 12psi?
Pressure Ratio:
Internal Ratio:
Intercooler: None
Camshaft
Cam Name: Stock Street/Economy
Intake Lift At Valve: 32.41mm
Exhaust Lift At Valve: 32.336mm
Lifter Type: None (Overhead Cam)
Lifter Acceleration Rate:
Valve Opening/Closing Based on:
Primary timing (Seat to Seat)
IVO 6
IVC 52
EVO 42
EVC 10
Secondary timing (0.050-inch)
IVO
IVC
EVO
EVC
Sorry about the mixed units.
Shortblock
Cylinders: 4
Bore: 96.9mm
Stroke: 75.00mm
Cylinder Heads
Intake Valves: 2
Exhaust Valves: 2
Compression
Induction
Island Flow:
Impeller Speed:
Peak Efficiency:
Surge Flow:
Belt Ratio:
Boost Limit: 12psi?
Pressure Ratio:
Internal Ratio:
Intercooler: None
Camshaft
IVO 6
IVC 52
EVO 42
EVC 10
IVO
IVC
EVO
EVC
