Rust Repair Thread
Posted: Sun Oct 02, 2005 10:10 pm
I figured...perhaps I could get this stickied and then anyone who has questions about rust can read this thread and ask questions if necessary.
So...you're seeing that bubbling near your wheel wells or anywhere else. If you don't know already...it's rust. The bubbling is the oxidation of the metal underneath the paint. If not taken care of early, the rust will spread and eat through your fender. However, there have been methods created to stave off rust. Today, we'll explore the bondo method of rust repair.
So..you can see in the picture below, the section of rust we're going to focus on today (it's the small section on the right).
In order to repair the rust, you must grind away the paint and rusted metal away from the area you're going to bondo. Should look something like this:
Now, we're going to take this bondo stuff here (which you should use in fairly warm/non-humid conditions):
According to the instructions, you mix the stuff in the can with the stuff in the tube (hardener) proportionally to the amount of area you want to cover (I used a very small amount). You can see the color of the mixture on the cardboard here:
You take your mixture and spread it on the affected area in a semi-fast manner (it will harden within 3-4 minutes):
After it gets hard (I gave it about 1.5 hours) you need to sand the bondo down so it looks good (and you don't have heeping amounts on your car...I did a poor job on this part...I did not sand enough away and I have a small bump where the bondo'd area starts):
After you've sanded it down, hit the area with a nice layer of Rustoleum (or the primer of your choice):
After the primer's dried hit the area with your matching color of spray paint:
After you've completed all that, you should have a decent looking patch for your rust. Note: When you're washing the car, take it easy on your patched areas. Note as well, you don't need to do bondo to fix an area if it's not very deep. You could just get away with grinding, primering, and painting.
