Need Engine Section of an FSM....
Posted: Tue Jan 31, 2006 8:08 pm
by BAC5.2
I need another engine section from an FSM. This one is a long shot though.
I need the engine specs for the EG33 from the SVX.
Standard FSM specs are what I need. Bore, stroke, rod and crank bearing journal widths, all that good stuff.
Anyone got it?
Posted: Tue Jan 31, 2006 8:40 pm
by sammydafish
Bore/Stroke is the same as an EJ22, 96.9x75mm I assume the rod length is the same as all the other Subaru engines of the era, EJ22, EJ20, EJ22T are all 130.5mm rods.
Posted: Wed Feb 01, 2006 1:34 am
by entirelyturbo
As best I know, sammy is correct. The EG33 is nothing more than an EJ22 with two extra cylinders, in the same way the ER27 in the XT6 was nothing more than an EA82 with two extra cylinders.
I can try to dig up some more info tomorrow at work though...
Posted: Wed Feb 01, 2006 3:36 am
may want to check out www.subaru-svx.net/forum if you haven't already.
Posted: Fri Feb 03, 2006 10:23 pm
by BAC5.2
I need to do some research on the motor.
As much info as possible would be great! Head info would be nice as well.
I want to be as prepared as possible when I get into the project.
I also need cam specs and such.
It may "just" be an EJ22 with 2 more cylinders, but I want some real specs.
Posted: Fri Feb 03, 2006 11:01 pm
by BAC5.2
I found a scan!
Posted: Sat Feb 04, 2006 9:59 pm
by AWD_addict
Now I'm curious. What is your project?
Posted: Sat Feb 04, 2006 10:55 pm
by BAC5.2
Top Secret. It will be something to be rekoned with though, that's for sure.
Posted: Sun Feb 05, 2006 3:12 am
by AWD_addict
Coolness, those are the best kinds of projects.
