crap (fixed)
Posted: Mon Mar 06, 2006 12:41 am
by bmxkelowna
well i washed my motor today
i only did a light rinse of every thing
and the motor was hot so most of the water evaporated right away
but i took it for a drive
and some things wrong
its compleatly gutless now from 5psi and up
i had a CEL so i shut it off and turned it back on, it went away
but its still like this.
what should i do? should i leave it and see how it is in later/in the morning?
Posted: Mon Mar 06, 2006 1:08 am
by Splinter
Wet knock sensor, would be my guess.
If you let the engine heat up all the way it should evaporate the water.
Posted: Mon Mar 06, 2006 1:12 am
by bmxkelowna
i did, i took it for a good drive before to warm it up, then i also took it for a dirve after to try to get rid of the water
Posted: Mon Mar 06, 2006 6:36 am
by bmxkelowna
well i just went for a drive and every thing is working how it should be. i guess it needed to be dryed out more. thanks guys
