Blowing things up, Doug vincent and anyone else boostin NAs
Posted: Tue Mar 28, 2006 5:46 pm
This thread is specificaly for Doug and anyone else that is boosting a NA engine. of course anyone with some experiance here feel free to chime in.
I ate the ringlands on 2 and 4 in my first motor before decent intercooling (didn't cut a scoop into the hood). The engine I've got now I assume has done the same as I'm low on compression on 2, but I have a rod knock too from blowing all the oil out when my turbo oil return line cracked. I didn't loost compression until after that happend and the bearing is bad enough that I'm pretty sure I can hear the piston taping the head. So I'm not sure if my compression loss is from killing ringlands due to boost or from smacking the piston up due to the rod knock.
No matter what I need a new engine, I'm wondering though if I should toss in another used NA engine, or if I should throw some forged slugs in the spare block I just stripped down. I'm kinda leaning towards doing another stock NA engine, simply because I want to know how far I can push it since I never got a chance to get a good turbo and a good tune on the engine before I broke it.
so Doug, how many engines have you been though on your rig? You still in the 155whp range? That's identical to what I was making on about 7-8psi ... what did you break and did you tear down and see why?
If I did build an engine, I'd put in forged pistons and keep the compression around the stock NA compression. I have a set of EJ25 SOHC heads and a manifold to throw on it. I want to keep my fuel economy and try to break the 200whp range. There was plans to make this a $2006 challenge car though, so keeping the price down in a must... not sure if I'll still have time to do the challenge, but I'd like to be able to if I could. I can still spend about another $700 on the car and be in the budget.
