Sams' non turbo SS and Ryans' nipple
Posted: Sun Oct 01, 2000 11:49 pm
Hey Sam, can't avoid raining on your parade a bit here but if you want the
real deal I have to bring you some words of reality. The plane Jane Legacy
Sedan and Wagons do not differ from the Sport Sedan/Touring Wagon by only an
engine. There's differences in the trans, the suspension, the brakes, the
ECU and in the case of auto trannys a separate stand alone TCU, and what
else...Oh yeah, the cooling system. That little coolant tank that shit
Ryan's' nipple has done the same thing to me. I epoxied it so heavy that I
changed my mind about a new tank, which I figure will not be as strong as the
one I patched. But the tank's just the tip of the iceberg. The radiators
bigger, and that tank is part of a system that causes water flow to continue
cooling the turbo with some kind of siphoning and vacuum action after you
shut down the engine. Bill and Matt can probably give you specifics on all
the changeouts you'll need to transform your Clark Kent into a factory spec
Superu Legacy Touring Wagon. It ain't from just putting on a red cape. And
you mentioned something about a MY 00 2.5? Please!!! Larry Witherspoon
