AVC-R installed !!
Posted: Sat Oct 07, 2000 12:29 pm
Hi People, I just installed the Apex-i AVC-R and doing setting.
Could any one tell me whats the highest Kg/cm for our turbo, should
the turbo cut at 12 psi or 8.4Kg/cm?? I just do the setting yesterday
and the boost just cut at around 8.3Kg/cm in heavy load (5 people and
going up hill)
If I don't turn on the boost control the car just has around 4 to 5
Kg/cm, its not as the factory boost out put? is there are something
wrong???
BTW, Shariff, whats the setting you did and I think I got the wrong
connection on the Throttle single wire, because the reading on the
meter is always shows 100% on the throttle, could you tell me which
one is for the throttle?
Have fun guys!!!
going up hill)
wrong???
Have fun guys!!!
