How hard to put 6 x 9's in the rear?
Posted: Tue Oct 03, 2006 4:14 pm
by neonglh
Our car's have 6.5" speakers all around, correct? I have a nice set of 6.5" for the fronts, and I have an extra set of 6 x 9's, and I am wondering how hard it woudl be to get them in the rear. I want some rear fill!
--mark
Posted: Tue Oct 03, 2006 9:51 pm
by Brat4by4
Some metal cutting and possible spacers because the tension rods for the trunk go right underneath the speakers there.
Posted: Wed Oct 04, 2006 4:01 am
by Murphy
is it ok to cut through that metal in the rear dash?
is it ok to remove the tension bars, or modify them?
Posted: Wed Oct 04, 2006 8:53 pm
by neonglh
Murphy wrote:is it ok to cut through that metal in the rear dash?
Why wouldnt it be? On my neon, I've drilled, but, modified pretty much every piece of metal on the car, so I think cuting the rear dash panel will be fine :D
--mark
Posted: Thu Oct 05, 2006 2:53 pm
by IronMonkeyL255
The tension bars you could remove, but your trunk wouldn't pop open anymore.
Posted: Thu Oct 05, 2006 5:50 pm
by neonglh
If were widening the holes, we should just be able to go in, instead of centering it in the current hole. This will make it clear the bars.
--mark
Posted: Fri Oct 06, 2006 6:23 am
by SuperRallyRoo
Other then the fact that 6"x9" speakers sound like ass... Ya its not a problem but why don't you just buy the correct speakers? Round speakers sound better and then you don't have to cut up your legacy!
Posted: Sat Oct 07, 2006 3:24 am
by Murphy
you still due if they are any larger at all, there is a hole in the metal dash made just the size of the stock speakers, my rears are blown, i have two rears in the garage laying around which i think happen to be 6x9s (about that size, they are oval shaped) as well, they are free and are 4way speakers
thats why i would want to cut it up
