td04
Posted: Thu Nov 09, 2006 1:07 am
by The Scooby
ok ive read through but i want to be clear.
swap a wrx turbo onto my 92 ss
use T-lego coolant lines, wrx lines work might have to be bent.
90degree inlet pipe
cut the coolant lines apart
up/down pipes bolt up i know, but should i replace the gaskets?
Thanks,
Shean
Posted: Thu Nov 09, 2006 1:14 am
by Binford
That sounds like the jist of it. New gaskets would be a good idea, but can be reused if neccisary. I actually have no gaskets on my setup. Oh well.
Posted: Fri Nov 10, 2006 6:18 am
by The Scooby
what about the oil lines? i know the return is the same, will the VF11 feed line bolt up?
and the coolant line i cut apart off the td04 and spun arround so it points at the stock coolant tank so that will work.
Posted: Fri Nov 10, 2006 4:43 pm
by Binford
Oil lines bolt right up.
Posted: Sun Nov 12, 2006 4:57 am
by The Scooby
ok well it took me about 1.5hours, but i have the turbo bolted in place, i ripped a coolant line so i have to go get a new hose tomarrow and make that up, also i used the wrx coolant lines, and the legacy oil lines, i couldn't for the life of me get the wrx return line to slip in, so i pulled the turbo back off, swapped it for the legacy one and it slipped right in.
now tomarrow when i get to work i just have to bolt the downpipe back up, the intercooler, and then cut the inlet radiator hose to length, and put in a peice of pipe to join it to the factory intake.
also im just running off wastgate boost for now, ill get a few miles on it then put the MBC back on before subie fest next weekend and then beat the crap out of it.
