Need help installing Hella 500 fogs (mostly w/ mounting)
Posted: Sat Nov 11, 2006 1:04 am
by jblair
I recently purchased a set of Hella 500 fog lights and I need help installing them. I'm pretty sure I can figure out the wiring, but I need help mounting them. I've searched this, and some other forums, but have not found a solid write up. I'm not too inventive when it comes to drilling, sawing, grinding, etc., so I'm looking for something easy.
Posted: Sat Nov 11, 2006 5:27 am
by tonflo
My PIAAs came with the heavy duty double sided tape & it has held up for 11 yrs now. If these aren't huge with only a tiny base to stick to, that may work for you. Mine are mounted in the factory foglight spots & there isn't much solid structure to drill into in the front bumper (which is why they are in those spots).
