fuel pump not getting any power.
Posted: Sat Jan 06, 2007 10:18 am
by malla
hey peop's,
we have just finished re-assembling a manual conversion on a 92 GT facelift legacy.
i have check all wires going into the fuel pump and its not getting a live feed.
we're not even getting the prime when ignition is on ACC.
the pump itself is fine.
Also(if this is any help) we're not getting all the dash board lights as well.
so i tapped into the main power(+) at the pump end and it worked pouring out petrol under the hood.
so i guess the problem is some where amongst all the wiring under the kick plate???
or maybe the computer isnt working??
any help would be greatly appreciated
thanks Malla
Posted: Sat Jan 06, 2007 4:02 pm
by ericem
I beleive there is a fuse for the fuel pump somewhere, i guess thats a good place to start.
But sounds like you got a leak somewhere in the fuel line.
Posted: Sat Jan 06, 2007 5:31 pm
by Manarius
Connector under the back seat might be fried. This is known to happen on occasion.
Posted: Sat Jan 06, 2007 9:08 pm
by gt2.5turbo
there is a relay tucked up behind the drivers side dash.. it could be bad... u might of missed a connector or something when you hooked things back up. i would start with the easy places like the wiring connector on the pump itself... the fuse... and so forth.
sux having wiring issues like this but all you can really do is start from one end and work your way to the source.
hope you figure it out cause an auto to manual swap is definitly rewarding when its all done
Posted: Sat Jan 06, 2007 9:43 pm
by malla
morning,
ok, im going to make a start on it now.....relay and fuse......
cheers peop's
Posted: Sun Jan 07, 2007 10:20 pm
There's no fuse. Only a relay. However if you're not getting dash lights, you've probably got a wiring issue or something you missed.
Posted: Thu Jan 11, 2007 10:16 am
by malla
upon completion of the GT conversion,i have started this week on my 89 RS.
droping in a new enginge,i decided to change the cam belt myself.
i know how to line everything up but im stuck on the tensioner.i had a feeling that i had to put a pin through to hold in place but ignored my intuition.so when the tensioner popped off, i cant seem to push the damn thing back in.
any ideas??
thanks Mal
Posted: Thu Jan 11, 2007 9:55 pm
by ericem
D'oh i meant relay relay relay
Posted: Fri Jan 12, 2007 1:08 am
malla wrote:upon completion of the GT conversion,i have started this week on my 89 RS.
any ideas??
thanks Mal
You need a vice or a c-clamp....and need to very slowly compress the timing belt tensioner.
Posted: Sun Jan 14, 2007 2:35 am
by malla
yep, got it done.
another Q, if your will the engine not start if the CEL reads code 22?
thats were im at now.
