B&G sport springs is it worth it?
Posted: Wed Apr 04, 2007 5:06 pm
by spdracr
ok, so i got a set of legacy wagon springs off a guy on a different forum, box says they will fit a 91-99 legacy wagon. pull them outa the box to find the rears are tapered. so after some searching I found that to make these work i need the rear tophats from a 90-91 n/a legacy. my question is...
do i just need the upper spring perches or do i need the top hat as these are two different parts.
also, where the 90-91 wagons about the same weight as my 99 outback wagon? I dont want to waste my time if i'm just gonna end up with the saggy rear end.
thanks..
-ben.t
Posted: Wed Apr 04, 2007 7:26 pm
by BAC5.2
If searched, you surely came across this question before.
I suggest searching again. Jamal made a thread, I've confirmed, the swap to convert from non-tapered to tapered springs has been covered more than Britney Spears has not.
Posted: Wed Apr 04, 2007 9:46 pm
by spdracr
yeah i was just hoping for a quick and dirty answer.
Posted: Wed Apr 04, 2007 9:58 pm
by jamal
I think all the 90-91 rear tops are one piece with the perch attached.
One other problem you might have is that the 90-91s have the lower spring perch at a different height on the strut. What that will do with those springs concerning ride height might be a mystery.
The only springs I personally would use on a wagon are the whitelines.
Posted: Wed Apr 04, 2007 10:40 pm
by BAC5.2
spdracr wrote:yeah i was just hoping for a quick and dirty answer.
In the future, please search.
