engine won't start.
Posted: Sun Apr 29, 2007 5:19 am
by asc_up
so came home today for dinner. my car was running great. i went back out ot my car after about 2 hours and tried to start it. it started but sounded like someone shoved pieces of sand and gravel into it. it just made a terrible grinding noise. then it quit after about 20 seconds. i tried restarting it tries to start but never actually catches and fires.
so any thoughts on what this could be?
Posted: Mon Apr 30, 2007 5:35 pm
Which car is this on....your 91 or 93? AT or MT?
Posted: Mon Apr 30, 2007 8:22 pm
by asc_up
it's on the 91 turbo with the mt.
i'm thinking it could be the timing belt/chain (not sure which one subarus have).
Posted: Mon Apr 30, 2007 9:19 pm
yeah it could be the timing belt. Chances are one of the idle pullies or gear bearings fried. Pull off one of the side covers and look.
Luckily these engines are non-interference.
I had the idler gear pulley go on a 91 tleg that I worked on
http://main.experiencetherave.com:8080/ ... ddedtbelt/
Posted: Mon Apr 30, 2007 10:07 pm
by asc_up
ok so i went to pull off the crank pulley and when i did the bolt broke off.
so i'm getting it towed tomorrow BUT i could see inside of the timing belt cover (i didn't bother pulling it off) and i could see a ball bearing on the bottom of it.
so now i'm left with two problems. i probably have a the seized pulley in there but now i'm left with a broken bolt. can that be replaced??
Posted: Mon Apr 30, 2007 10:28 pm
by 555BCTurbo
Broken pulley bolts are not good...
No offense, but it sounds like your repairs may be best left up to a shop...and in your area I would recommend Pacific Import Auto
Posted: Mon Apr 30, 2007 11:58 pm
by asc_up
haha oh trust me...i know. it's getting towed to RooPair tomorrow. lol it's a subaru shop.
argh i hate how much i love this car. it's making me sad not being able to drive it lol.
Posted: Tue May 01, 2007 10:24 pm
by asc_up
so the car was towed today and dan at roopair is taking a look at it.
he said what probably happened is that the previous owner did not tighten down the crank pulley well enough so it wobbled and basically destroyed itself and some other timing pulleys or whatever lol.
he has to rip out the engine to drill out the broken bolt so i'm going to have him put on a new clutch
BUT he said that the crankshaft might be ripped to shreds and he said it would be cheaper for me to buy a new engine than to have him try to fix it...
Posted: Wed May 02, 2007 10:43 pm
by asc_up
so an update:
I = Screwed lol.
the entired crankshaft has ripped apart the engine lol. it slides back and forth about 2" either way. my mechanic said it will be cheaper for him to drop in a new engine than for him to replace the damaged shaft.
that's only going to cost me $2500....
considering i paid 3K for the car sucks even more.
aaahhhhh damnit.
Posted: Wed May 02, 2007 11:12 pm
by PhyrraM
A good used engine should only be about $1000 + install.
Not sure what your mechanic quoted you but compared to other cars Subaru motors basically fall out of the engine bay. If you source then engine and let them R&R it you can prolly get away with a bit of change in your wallet left.
Posted: Thu May 03, 2007 12:11 am
by asc_up
yeah the mechanic said 2500 for him to put on a new shortblock.
i'm thinking that i'll go find a used engine and drop it in myself.
grrrr these next few weeks are going to be great...
Posted: Fri May 11, 2007 11:38 pm
by Arctic Assassian
the quote was so high because that was a shortblock. doing that requires swapping heads, intake mani, a few gaskets, its way more work then just dropping in a used engine.
