FS: 94' LEGACY SS
Posted: Thu Jun 14, 2007 12:09 am
'94 SS auto, 240kms (Canada). 4EAT is acting up. Decent body.WRX rims, silver. All accecories work including CD. $1200 CAN[/b]
A forum for 89-94 BC-BF(BJ) Legacy Owners and Fans
https://bbs.legacycentral.org/
New tires (if you want to use the tires on it now) Altough I have the OEM rims with good tires mounted on that will be included. Front Left outer tie rod. The mechanicals is sound engine, turbo, emissions control system (no CEL). The Airbag light is on though because some work was done on the ignition switch recently and the airbag wiring had to be disconnected. No the Airbag light will not go off. Maybe this can be easily fixed. The A/C compressor des not work (low refridgerant most likely).Innovative Tuning wrote:What does it need to pass inspection?
Does everything work properly? (tranny aside)
Does the sunroof leak?
When was the timing belt last replaced?
No trouble lights? (CEL , ABS , Air Bag, etc.)
Is it drivable with the tranny acting up? What is it doing?
Thanks,
Mike
