Impreza is making some strange noises
Posted: Tue Jul 24, 2007 4:58 pm
My 97 Impreza has started making some weird clunks/noises.
It sounds like something is loose. I mainly hear it when going over bumps at low speeds, or just when starting out. It even seems to make some noise when I depress the brake pedal after moving slightly, and them coming to a stop. Other times, I can hear a squeaking (what sounds like metal on metal) when I turn the wheel slightly from center.
I have jacked the car up and did the yank on the wheel test...everything seems secure. The only thing I did find was that the steering rack boot has a tear in it where the clamp holds it to the tie rod. It appears it was replaced before with an aftermarket boot that was too small. I ended up running through some deep water a few weeks ago, and probably got water in there. I could see the squeeking noise coming from the rack, but I don't really see how the rack could be making the clunking noise......I don't know....
Thoughts?
Thoughts?
