Please confirm part numbers for KYB AGX application
Posted: Mon Aug 27, 2007 11:28 pm
by macipusy
I want to purchase KYB AGX struts for my 91 SS. I contacted CVR Motorsports and they said that I should go with 98-01 Impreza application with the following part numbers:
733010
733011
734006
734007
Please confirm that these will inface work on my 91 turbo sedan without changing perch height.
I will be using these with GC coilover sleeves.
Posted: Mon Aug 27, 2007 11:39 pm
by jamal
all of this should have stayed in one thread. You don't need four to discuss the same thing and it makes it a lot harder to search for this stuff in the future.
And like I've said a half dozen times, you're not using the perches on the struts, and the ground control sleeves are height adjustable, so it doesn't matter. The only thing you need to do is switch to the 92-94 or 93-01 rear top hats.
Posted: Tue Aug 28, 2007 7:03 pm
by IronMonkeyL255
I posted in the other thread these same part numbers.
Using '92-'94 rear tophats, I am using the GR2 version of the same struts (listed for the '93-'01 Impreza). I am positive that they will fit without throwing off the alignment settings.
Posted: Tue Aug 28, 2007 10:06 pm
by adema2626
You can use any 93-01 KYB's the top hats are the only difference and there only different because the Legacy rear springs get really small at the top when Impreza's don't. But the front top hats are the same as imps and the rears are smaller only because of springs so you can use imp rear top hats no problem.
