Question about reving motor in Park
Posted: Wed Oct 10, 2007 12:44 am
How responsive should it be to the throttle? I find it to be not very responive like if i floor it takes like 3/4 of a second to respond, doesn't even seem to respond quickly if i give it light throttle either. Could this explain why the car seems like it lost power? I am wondering if I should change the o2 sensor as I think i should get better then 19mpg on a N/A. So far the engine has been seafoamed, air filter replaced, plugs and wires replaced, MAF sensor cleaned with electronic cleaner, fuel filter replaced, but with a non oem filter, PCV replaced, cracked knock sensor replaced, ECU temp sensor replaced. What I noticed though was my spark plugs with only like maybe 5,000KM were very carboned up and black and one plug even had sludge on the tip. The plugs were NGK G powers. This time I am using V-powers but seems to drive the same. Help is well appreciated thanks. Sorry for the long post.
