I bet your right, I'm gonna go change that fluid afterall if it gets hot then maybe it thins and is less efficient.
Makes sense to me
cheero
John
----- Original Message -----
nzwrc1@sunlink.net> Scicchitano
To:
BC-BFLegacyWorks@egroups.com
Sent: Thursday, November 23, 2000 8:16 AM
Subject: [BC-BFLegacyWorks] Re: Steering gets tuffer and tuffer.
How long ago was the fluid changed last? Since ATF is basically a
hydraulic fluid, I'm guessing over time that dirt and moisture hamper
it's ability to build pressure. Before my steering rack failed, the
steering began to get stiffer. I changed the fluid and put in
synthetic ATF, and the steering felt MUCH better for almost a year,
but unfortunately the damage was already done to the rack and it
needed replaced, but new fluid does wonders and is often overlooked.
A good habit to get into with power steering fluid is drain and
replace 100 percent of it from the rack itself, then at every oil
change there after, suck out the steering fluid from the resivoir and
replace it with new. This keeps practically new fluid in the steering
system at all times. Since the entire system holds less then a quart,
you won't go broke changing it at every oil change.
-Matt
--- In
BC-BFLegacyWorks@egroups.com, "penty" < penty@n...> wrote:
> In the beginning I thought it was my imagination, but my steering
definatly gets harder to turn the more I drive it It, there are no
funny noises or anything so what an earth could cause this?
> Wierd!
> or maybe I just get more and more feeble
> cheers
> John
-------------------------- eGroups Sponsor -------------------------~-~>
eLerts
It's Easy. It's Fun. Best of All, it's Free!
http://click.egroups.com/1/9699/1/_/_/_/974967391/
---------------------------------------------------------------------_->
eGroups Sponsor
http://rd.yahoo.com/M=150967.1016644.27 ... =975002335?> click here
