Steering gets tuffer and tuffer.
Posted: Wed Nov 22, 2000 2:39 pm
by penty
In the beginning I thought it was my imagination, but my steering definatly gets harder to turn the more I drive it It, there are no funny noises or anything so what an earth could cause this?
Wierd!
or maybe I just get more and more feeble :)
cheers
John
eGroups Sponsor
<http://rd.yahoo.com/M=150967.1016644.27 ... =974921979?> click here
Posted: Wed Nov 22, 2000 4:53 pm
by Miguelito
Not trying to offend you (no way Hosé!), but you'll hear this from
someone else anyway... you've checked the fluid... haven't you... ;)
cheers
Miguelito
> Wierd!
> cheers
> John
eGroups eLerts
http://click.egroups.com/1/9698/1/_/_/_/974929957/
Posted: Thu Nov 23, 2000 3:16 am
by Matt Scicchitano
How long ago was the fluid changed last? Since ATF is basically a
hydraulic fluid, I'm guessing over time that dirt and moisture hamper
it's ability to build pressure. Before my steering rack failed, the
steering began to get stiffer. I changed the fluid and put in
synthetic ATF, and the steering felt MUCH better for almost a year,
but unfortunately the damage was already done to the rack and it
needed replaced, but new fluid does wonders and is often overlooked.
A good habit to get into with power steering fluid is drain and
replace 100 percent of it from the rack itself, then at every oil
change there after, suck out the steering fluid from the resivoir and
replace it with new. This keeps practically new fluid in the steering
system at all times. Since the entire system holds less then a quart,
you won't go broke changing it at every oil change.
-Matt
> Wierd!
> cheers
> John
eLerts
http://click.egroups.com/1/9699/1/_/_/_/974967391/
Posted: Thu Nov 23, 2000 7:08 am
by JohnnyG
Geez... check your steering pump for fluid level, steering pump, hose and rack for leaks.... wheel alignment and tyre pressures.
Umm... loose nut behind the steering wheel?
John Gillon
----- Original Message -----
To: Legacy egroup <mailto:BC-BFLegacyWorks@egroups.com>
Sent: Thursday, November 23, 2000 8:41 AM
Subject: [BC-BFLegacyWorks] Steering gets tuffer and tuffer.
Wierd!
cheers
John
eGroups Sponsor
<http://rd.yahoo.com/M=150967.1016644.27 ... =974981323?> click here
Posted: Thu Nov 23, 2000 10:47 am
by penty
Hi!
mmmm yes good idea........... but ( there always a but :))
at the moment my wheel alighnment is like eddy monster ( crosseyed as a muel ) because I have a worn trackrod arm that moves about 4 mm, but why would this change the stiffness the longer I drive it from cold ?
so many questions :)
cheers
John
ps <mailto:grilla@ihug.co.nz> JohnnyG said <Umm... loose nut behind the steering wheel?>
Do you mean ME :O because I'm as nutty as a fruit cake :p)-(
To: BC-BFLegacyWorks@egroups.com
Sent: Thursday, November 23, 2000 125 PM
Subject: Re: [BC-BFLegacyWorks] Steering gets tuffer and tuffer.
John Gillon
Wierd!
cheers
John
eGroups Sponsor
<http://rd.yahoo.com/M=150967.1016644.27 ... =974994438?> click here
Posted: Thu Nov 23, 2000 12:59 pm
by penty
I bet your right, I'm gonna go change that fluid afterall if it gets hot then maybe it thins and is less efficient.
Makes sense to me
cheero
John
Sent: Thursday, November 23, 2000 8:16 AM
Subject: [BC-BFLegacyWorks] Re: Steering gets tuffer and tuffer.
-Matt
> Wierd!
> cheers
> John
eLerts
eGroups Sponsor
<http://rd.yahoo.com/M=150967.1016644.27 ... =975002335?> click here
Posted: Thu Nov 23, 2000 1:04 pm
by penty
I sure did
cheero
John
Sent: Wednesday, November 22, 2000 9:52 PM
cheers
Miguelito
> Wierd!
> cheers
> John
eGroups eLerts
eGroups Sponsor
<http://rd.yahoo.com/M=150967.1016644.27 ... =975002660?> click here
Posted: Sat Nov 25, 2000 4:26 am
by JohnnyG
John,
You have answered your own question... fix your track rod and steering allignment! Your cold to hot variation, is probably due to the steering pump fluid loosing viscosity as it heats... or if your problem is very severe, maybe the tires getting better adhesion as they heat.
Fix it... most stock suspension Legacy's chew the edges off their tyre as it is.
John Gillon
Sent: Friday, November 24, 2000 4:49 AM
Hi!
cheers
John
John Gillon
Wierd!
cheers
John
eGroups Sponsor
<http://rd.yahoo.com/M=150967.1016644.27 ... =975144385?> click here
