Page 1 of 2
More images of the Subaru Turbo Diesel motor
Posted: Mon Dec 24, 2007 5:25 pm
by dropdfocus
While doing a google search for images to use for my monitor's background, I stumbled on to this page (Subaru Turbo Diesel):
http://ymmv.coffeehaus.com/archives/005106.html
Posted: Mon Dec 24, 2007 8:52 pm
Pretty cool.
Posted: Tue Dec 25, 2007 10:00 pm
by Adam West
Don't miss the engine video at the very bottom. Terrific graphics!!!
Thanks for posting!!!!
Posted: Wed Dec 26, 2007 1:41 am
by dropdfocus
Not a problem. I figured it would make someone's day for sure.
Posted: Thu Dec 27, 2007 2:27 am
by SubaruNation
"intelligent mode"
thanks toyota....ish
Update on der diesel
Posted: Sun Feb 10, 2008 12:19 am
by tonflo
Posted: Sun Feb 10, 2008 12:32 am
by SubaruNation
that would be sweet if they did bring that here to compete with the mercedes and BMW's that are already diesel and are already here.
Posted: Sun Feb 10, 2008 12:44 am
by evolutionmovement
It's even shorter than the gas 4-cylinder. I would love to use this engine in my project if it can fit width-wise. I could really use the low cg and the short length would be a huge help providing space for my inboard suspension and radiator with shrouds.
Posted: Sun Feb 10, 2008 1:18 am
by New92
ADA=You cant have fun in this car!
I like the location of the turbo, that would certainly help with cooling.
Posted: Sun Feb 10, 2008 2:13 am
by Aerotech
I would love to have one of those motors for my van... I have a feeling the control electronics would not be very much fun to deal with in a swap.
The Science Channel just ran a program about the new BMW diesel motors. Twin-turbo straight-6 coming in the fall in the 3-series. All Aluminum block, gobs of torque, and clean emmisions. Finally a decent diesel that's not housed in a damn Jetta! I'm not holding my breath for Subaru to bring it's boxer diesel here soon.
Posted: Sun Feb 10, 2008 2:23 am
I don't want their 6 - I want the 2.0 in the 118d. That car gets 60 mpg and still gets out of its own way while weighing more than double what my project car will and with far worse aerodynamics. And it has stop/start and accessories that only run when needed. That's my other option if the Subaru engine turns out to be too hard to get or too wide to fit.
Posted: Tue Feb 12, 2008 5:12 am
by Aerotech
evolutionmovement wrote:I don't want their 6 - I want the 2.0 in the 118d. That car gets 60 mpg and still gets out of its own way while weighing more than double what my project car will and with far worse aerodynamics. And it has stop/start and accessories that only run when needed. That's my other option if the Subaru engine turns out to be too hard to get or too wide to fit.
That's another one we'll never see. To far downmarket to fit BMW's "U.S. Image" of ultimate driving machine. You'll have to buy a front clip from Europe, or perhaps Canada will get this beautiful motor, and we can sneak it across soon...it was also highlighted in that SciChan show.
I don't have that much against the VW TDi, it's a nice motor, but it's a really old design, iron block... typical VW; stretching out a design as long as possible, instead of innovating. Same reason I'm putting a Subaru motor into my Vanagon; the stock motor was a 1933 design beetle engine with a water jacket. Pushrods, for fuck's sake...
Posted: Tue Feb 12, 2008 5:14 am
by 555BCTurbo
They are fantastic driving motors though...
Posted: Tue Feb 12, 2008 5:48 am
by jamal
I wonder...
Will it be possible to swap gas internals and heads into that block? It should be strong enough for VERY high hp applications...
Posted: Tue Feb 12, 2008 6:20 am
by 555BCTurbo
jamal wrote:I wonder...
That block doesn't look like it shares much anything with an EJ
Posted: Thu Feb 14, 2008 3:03 am
by beatersubi
Aerotech wrote:Pushrods, for fuck's sake...
Pushrods do the General proud to this very day. The new ZR1 makes somewhere north of 600hp. Off a showroom floor, thats not bad, IMO.
Posted: Thu Feb 14, 2008 3:05 am
by 555BCTurbo
You also can make a turd fast, but then it's just a fast turd
Posted: Thu Feb 14, 2008 5:20 am
Except the LS series also gets better gas mileage and packages better than most contemporary smaller DOHC units that make less power at higher rpm. And that's without cylinder deactivation.
You can have the most advanced composite knife in the world, but I'll still take a regular axe when I need to chop wood. OHC is not new tech either.
I don't think I'll have to smuggle a 118d front clip over after all - reading the EPA papers on importation, it looks like it's considered car parts and is not subject to emissions and since it will likely be technically going into a motorcycle passing emissions is no issue. There are a couple options, it appears, without having to resort to smuggling one over the border from a Canada ship-to.
Posted: Thu Feb 14, 2008 6:26 am
by 555BCTurbo
evolutionmovement wrote:Except the LS series also gets better gas mileage
That's because the overdrives they put with them are crazy high...it has little to do with the actual motor.
Laura's mom and dad have a GTO auto and it gets crappy mileage...and it has an LS2
Posted: Thu Feb 14, 2008 6:08 pm
Of course it does! Try running that kind of overdrive in a Honda Civic - you need low end torque to pull those ratios.
Posted: Fri Feb 15, 2008 3:17 am
by James614
The LS series doesn't get better gas mileage
The
Corvette does because it's a featherweight and can scoot with your toenail on the gas. GTOs, Impalas, Grand Prixs, etc (the heavyweight LS-powered cars that real people can afford) all get much less spectacular mileage.
I'm tired of manufactuers not bringing diesels over here because they aren't sure our market is ready for it. Do they seriously not see the popularity of small cars (Yaris, Fit, etc), hybrids, and our culture's willingness to buy $60 "gas mileage improver" packages from PepBoys? An Outback 2.0D may be slow as balls, but I don't think anyone would complain about getting 50mpg and having the torque to pull back V6 Jeeps!!!
Posted: Fri Feb 15, 2008 3:31 am
But the Corvette has used a series of LS engines, all of which were capable of decent mileage, better mileage in many cases than smaller (capacity, though larger physically), less powerful DOHC units. Anything heavy with bad aerodynamics will not get good mileage regardless of engine. Too small an engine will get bad mileage as well as you have to wring the hell out of it to move the vehicle. Combine the larger engine with cylinder deactivation so you're not fueling 6 liters in traffic and you can get some pretty impressive numbers.
It's very similar to a diesel with the low end torque allowing for tall gearing. Who cares about revs when they don't need them. Of course, diesels are more efficient than gas to begin with. Plugging in the numbers, my vehicle will lose little performance using the 118d's drivetrain than an S2000's with far greater mileage.
Posted: Fri Feb 15, 2008 5:04 am
by 555BCTurbo
Yeah...diesels really do own everything...
I honestly think that they are the only viable future of transportation at this point...
Since you can make the fuel from fryer oil...
Posted: Fri Feb 15, 2008 5:20 am
by James614
evolutionmovement wrote:But the Corvette has used a series of LS engines, all of which were capable of decent mileage, better mileage in many cases than smaller (capacity, though larger physically), less powerful DOHC units.
Now I think it's time to specify what specific other DOHC engines your talking about, which could change my stance substantially....
555BCTurbo wrote:Since you can make the fuel from fryer oil...
Straining old grease doesn't qualify as "making" the fuel
Posted: Fri Feb 15, 2008 5:21 am
by 555BCTurbo
I agree...but where do you think that Biodiesel comes from?
Bio and Waste Veggie Oil are 2 very different things
