vibrant Ide up to 2 and 0?
Posted: Sat Dec 29, 2007 5:46 pm
by awssubaruls
Hi
today in the morning when i start to heat my car i see vibrant Ide up to 2rpm and Zero. i mean my rpm not stable .
B.R
Posted: Sat Dec 29, 2007 6:36 pm
by ericem
You probably have to clean the IAC valve.
To bad in Iraq they don't have any car parts or additives so you can clean it. Your going to have to import some spark plugs, and wires from europe or asia man. How much did Subaru in the Midwest say it will cost for spark plugs and wires? Do you have WD40 over there? If you do you can spray that down the tube for the IAC and it should clean it out just fine.
Posted: Sat Dec 29, 2007 7:08 pm
by awssubaruls
ericem wrote:You probably have to clean the IAC valve.
thanks dude i'wll do it
Posted: Sat Dec 29, 2007 10:05 pm
by Jutboy
Clean the PCV valve while your there and make sure you mark the position on your IAC
Posted: Sun Dec 30, 2007 8:31 pm
by awssubaruls
Jutboy wrote:Clean the PCV valve while your there and make sure you mark the position on your IAC
how i mark my IAC position onmyIAC
