18PSI boost
Posted: Thu Nov 23, 2000 9:55 am
by awdturbodude@yahoo.com
I guess a boost controller wouldn't hurt... I talked to the guys at
Tuning Chip in Sweden (http://www.tuningchip.com), and they have a
controller supposed to be much like the Hallman one
(http://www.hallmanboostcontroller.com) and for a very nice price
too. I thought that it would be a good idea to control the boost
somehow. Any comments...
cheers,
Miguelito
--- In BC-BFLegacyWorks@egroups.com, "JohnnyG" <grilla@i...> wrote:
> 11 to 12lb is about right for a stock EJ20 220hp... if you have no
other
> wastegate atuator delaying mods, you have a chip which is probably
raising
> the MAP sensor input sensing to "fool" the engine management system.
> Mind you... running 18lb on a stock MAP sensor must be getting
close to
> "flat-lining" the sensor output. If you have no other boost control
or
> engine strengthening, you are asking for trouble runniing 18lb.
> The name of the game is to build boost early... not raise the peak
boost as
> such.
> John Gillon
> ----- Original Message -----
> From: Miguelito <awdturbodude@y...>
> To: <BC-BFLegacyWorks@egroups.com>
> Sent: Thursday, November 23, 2000 10:47 AM
> Subject: [BC-BFLegacyWorks] RE: EJ20G HP's
> > Hi John (again...)
> > I'd guess your car is 'bout the same as mine... here it's just
> > called "200 Turbo"... my guess is therefore that you should have
> > 200HP (stock).
> > However, I recommened that you dyno-test it, cause the garage
where
> > all modifications were made to my car ( www.stmotors.fi ), they
told
> > me that the actual power output varies a lot amongst Subarus. For
> > example, my previous car was also a 200 Turbo, '92 model, chip
> > upgraded, and when we drove it on their dyno, it only had
216HP... no
> > other mods were made on that car, but anyway... They've had some
> > (stock) turbo Legacies there with under 200HP when tested.
> > Another thing, you say you run it on 11 psi boost, if I've
converted
> > that correctly, it's 'bout 0.75 bar (correct me if I'm wrong!),
and
> > that sounds a bit low. Is that 11psi on fourth or fifth gear,
going
> > up a hill with your foot half an inch thru the floor... Don't get
me
> > wrong, that's how I measure the top boost on my car. Anyway, under
> > those circumstances I have 'bout 18psi boost (again, calculating
it
> > from 1.25bar).
> > I could of course be VERY wrong here... maybe this is the moment
to
> > ask someone how psi is converted to bar, and vice versa!
> > cheers,
> > Miguelito
> > --- In BC-BFLegacyWorks@egroups.com, "penty" <penty@n...> wrote:
> > > Hi
> > > Does anybody happen to know what HP I have on my 2L Lagacy 4 cam
> > turbo I am from the UK so it has water intercooler as standard.
> > > What is standard for this car ? and now I have it at 11 psi
boost ?
> > > Thanks in advance
> > > John
> > > From: JohnnyG
> > > To: BC-BFLegacyWorks@egroups.com
> > > Sent: Wednesday, November 22, 2000 65 AM
> > > Subject: Re: [BC-BFLegacyWorks] LegacyWorks Registry
> > > Perfectly logical engine configuration for your model, Ralph
> > > I have learnt from this forum, that the UK / Euro 200hp
version
> > is a variant
> > > on the Japanese 220hp version... probably to meet your
emission
> > > regulations... I guess that what the NW2BD suffix defines.
> > > John Gillon
> > > From: RALPH <ralph.jarvis@u...>
> > > Sent: Wednesday, November 22, 2000 102 AM
> > > > Just to confuse matters more on the issue
> > > > of engine models etc...
> > > > I own a 1994 BC 2L Quad cam intercooled
> > > > turbo.(200hp model)
> > > > The engine IS a EJ20G (EJ20GNW2BD)
> > > > but it has a sand cast block and hydrolic
> > > > lifters.
> > > > Now where does that leave us!!!!
> > > > Hmmmmmmmmm
> > > > Ralph :->
> > > To unsubscribe from this group, send an email to:
> > > BC-BFLegacyWorks-unsubscribe@egroups.com
eGroups eLerts
http://click.egroups.com/1/9698/1/_/_/_/974991341/
