Codes causing other codes maybe?
Posted: Mon Feb 04, 2008 8:00 am
by adema2626
So im throwing 5 different codes on my 93 Legacy N/A motor. I was wondering if i was throwing one of these certain codes would it make it some of the other codes get throwing if that one was going off? The codes being throwing are
11=crank angle sensor
13=cam angle sensor
14=injector 1
16=injector 3
32=oxygen sensor
Does one of those codes cause some of the other ones to fire? I'm pretty sure that the injectors are clogged so pretty much discard those codes but do any of the other ones make it so that it would throw the other two? Any help would be appreciated thanks
Posted: Mon Feb 04, 2008 1:35 pm
Does the engine run?
Yes, it's possible for one problem to trip multiple codes. The factory service manual recommends addressing the codes with the lowest numbers first.
Posted: Mon Feb 04, 2008 8:53 pm
by adema2626
Nope it does not run, got it to fire in 2 or 4 because it started to fire then it died. So im thinking the injectors are clogged or something? If they were would that cause them to throw a code?
Posted: Mon Feb 04, 2008 9:04 pm
It could cause them to throw a code, yes, but I'd first suspect the cam and crank sensors.
Why do you think the injectors are clogged?
