I bought a turbo...
Posted: Fri May 16, 2008 9:58 am
So I purchased a turbo from a member. The pin that the wastegate actuator attaches to is bent from shipping, the front seal leaks, as evidenced by the backside of the compressor wheel. The wheel itself looks to be damaged by someone removing the compressor housing, because it is not uniform across all fins.
Anyone have a good lead on a compressor wheel for a TD05-16g? I'm thinking of replacing the seal myself, anyone done that before? On a side note, I am gonna replace the 2.2 with an 05 n/a 2.5 temporarily, running wastegate boost(11lbs) from a TD04L. Anyone see any problems?
-Adam
-Adam
