Boost gauge install
Posted: Wed Jul 02, 2008 10:37 pm
by joshm
Hey everyone, i just picked up a '91 turbo legacy sedan, and am wanting to install a boost gauge. I bought a manual boost gauge, and i can see that i just put the "t" splitter into a vacuum line. However, im unsure as to which vacuum line i install it in to see my turbos boost ? thanks for the help
Posted: Wed Jul 02, 2008 11:54 pm
by New92
Welcome to the best car forum ever, keep an open mind and take the time to read things thru and you will find this site to be a true trove of information.
Do a quick search thru the faqs:
http://legacycentral.org/library/boost.htm
As to mounting......I used a band clamp, screwed to the steering column cover, centered on the tach, the whole thing painted black. There are countless other options available for you. You really should search a bit more, this topic has been done to death.
edit) If you need pics or anything, let me know! Good luck and congrats on a great acquisition.
Posted: Thu Jul 03, 2008 12:04 am
by joshm
So, where is the nipple on the turbo :S I cant even see my turbo its buried down so far ! New92, can you take a pic of where i should hook up the line too ? Im still confused ! Thanks so much.
Posted: Thu Jul 03, 2008 12:19 am
by New92
Yeah, I can put up a pic for you......however, if you can look at the car a second Ill guide you. I dont know your knowledge so dont get bent if this is too simple.
Pop the hood and locate your intake plenum, this piece is what feeds the air from your throttle body (TB) to the top end of the engine.
You will see two (2) "runners" on the left side (passenger side) and from one of these runners (the forward runner I think) a vacuum line running to the left towards your airbox. TAP/T into this line and you will have the best source for your vac/boost readings.
As a suggestion, you can also pick up some vac hose, slice it down the middle, and use it as a cover to shield the nylon hose feeding your gauge.
Posted: Thu Jul 03, 2008 12:31 am
by joshm
I can change the tranny in my jeep, but i cant find a vacuum hose on my roo ! Can you please show me which hose it is in this picture, theres so much of everything under this engine compartment it confuses me :lol:
56k LOOKOUT!!
Posted: Thu Jul 03, 2008 12:48 am
by New92
No problem, here are some pics from my own vehicle. "Please snicker quietly at my ghetto fabrication" Thank you :P
That help?
Posted: Thu Jul 03, 2008 7:14 am
by joshm
Thanks so much for the help new. So its this line right ? Should i go on the side of the existing "t" closest to the intake manifold, or closest to the air box. (to right or left of existing T in that line, in reference to my drawing circled)
Posted: Thu Jul 03, 2008 7:29 am
by ciper
Any line coming from the throttle body between the throttle plate and intake valves will technically work but yes thats the line.
Posted: Thu Jul 03, 2008 9:05 am
by Dynamic Entry
right exactly where you circled. right there.
PS. NEW92, those are tidy inked-pics!
PPS. I had a few tonight and I have to work in 5 hours..... =)
Posted: Thu Jul 03, 2008 2:32 pm
by New92
Dynamic Entry wrote: PPS. I had a few tonight and I have to work in 5 hours..... =)
HA! I was up nursing one too. Finished up early for the week so now Ive got off 4 days! Guess Ill be installing my WRX scoop.
Posted: Fri Jul 04, 2008 3:26 am
by joshm
Well i got my wisdom teeth yanked today, i have the energy to do it, but i dont wanna be in pain for more then i have to so im takin it easy now
