So what do ya guys think...Ebay...?
Posted: Fri Jul 11, 2008 5:00 am
by 94SS_Canada
So what Do you guys think about this for my build?
Im not aiming for that much power but would be nice to have for longevity and a little abuse....
ebay link
Using Stock Fltwheel also, Does it sound like a good plan? I need an answer quick as my parents need me outta there garage
Posted: Fri Jul 11, 2008 6:09 pm
by 94SS_Canada
I really need some input, from the pros
Posted: Fri Jul 11, 2008 7:23 pm
by Fkyx
Seems like that clutch would be a big B in a daily driver.
Posted: Fri Jul 11, 2008 7:54 pm
by n2x4
I say no. Your transmission can't handle that kind of abuse. I'd rather have my clutch go instead of a gear. How much power are you planing on making? A stock WRX clutch is good to about 300HP. I vote Exedy WRX clutch, like $164
That six puck is something like Doug V. would be running. Are you looking for power figures like he has?
Posted: Fri Jul 11, 2008 9:20 pm
by 94SS_Canada
Im not aiming for huge power
Will that WRX clutch work with my stock pressure plate and flywheel?
Where can i get one? on ebay? Could you post a link, thanks
Posted: Fri Jul 11, 2008 9:24 pm
by 94SS_Canada
im aiming for somewhere between WRX and STI power. Itll basically be a wrx, with a TD04 and wrx topfeed blues except on an EJ22T with EJ25 heads and manifold and a FMIC
Posted: Fri Jul 11, 2008 9:55 pm
by n2x4
like this:
Ebay link
From NASIOC clutch FAQ
http://forums.nasioc.com/forums/showthread.php?t=775679 -
How much torque will the OEM 5MT and 6MT clutches hold? Though no one knows for sure, common knowledge say that the 5MT will hold 300 TQ and the 6 MT will hold 400 TQ.
I don't think I'd go with much higher than a Stage 1 clutch at the most. My logic is this: With all that power, there's got to be a weak link. If it's not the clutch, then it's the transmission.
EDIT: Oh, and that will work with the stock flywheel. I've been running one for about 20k miles now.
Posted: Fri Jul 11, 2008 10:09 pm
by NuclearBacon
I have a stage 1 Exedy Organic clutch (with a lightweight flywheel) and stock boost, catback exhaust (nothing for power) and i can break the tires loose, yet get stuck in LA traffic for 4 hours, and still be ok.
I LOVE my clutch
my $0.02
Posted: Fri Jul 11, 2008 10:30 pm
by New92
Look for a wrecked "parts car" I got the full deal flywheel, pressure plate, disc and bearing all for like $80. I threw in a stage1 disc and it works great.
Posted: Fri Jul 11, 2008 11:14 pm
by asc_up
GripForce
This ebay store will solve all of your problems. Buy a kit for a WRX (not STi). They're low priced, quality clutches. I can testify to that and I believe that there are a few other members on here that will, too.
Personally, I bought a Exedy Stage 2 clutch kit. It took a bit of getting used to, but it's great. I think a Stage 1 would've been just fine.
I highly recommend that you stay away from pucked clutches.
Posted: Sat Jul 12, 2008 7:52 am
by 94SS_Canada
okay thanks for the info guys, it looks like my stock clutch probally could hold it, but im replacing it anyways.
Thanks for the links also, i still cant find what i need could somebody find me what im looking for and post a link?
thanks, i appreciate allllll the help
Posted: Sat Jul 12, 2008 7:39 pm
by 94SS_Canada
I don't know how to read the ebay link rules found here and
here
What about this, it seems a little weak, 294tq, i guess i wont have that much at the crank....
What do the flwwheel bolts have to be torqued to? Will that clutch even work?
Mod edit: Sorry, I'm not singling out you, I'm just tired of changing everyone's damn ebay links
Posted: Sat Jul 12, 2008 9:51 pm
by asc_up
Yes that clutch will work perfectly.
I don't know what the FW bolts have to be torqued to. I just tightened the shit out of mine lol. It's held up for almost 2 years now...
Posted: Sun Jul 13, 2008 5:14 am
by SILINC3R
solid puck-daily driver
4 puck- daily more grip
6 puck- a bicth in traffic. for racing use
Posted: Sun Jul 13, 2008 5:19 am
by SILINC3R
this will help
http://www.fidanza.com/
watch the video
Posted: Sun Jul 13, 2008 5:32 am
by 94SS_Canada
So will this clutch work with my car, it says it is for a WRX and my Car is a 1994 subaru legacy turbo.
What happens when the wwrong clutch comes to my doorstep, can someone confirm?
Posted: Sun Jul 13, 2008 6:05 am
by 94SS_Canada
Posted: Sun Jul 13, 2008 6:49 am
by asc_up
I know for a fact that a clutch kit for an 02-05 WRX will work with your 1994 Subaru Legacy Turbo. I don't know how to make it any more clear.
Posted: Sun Jul 13, 2008 12:55 pm
by BAC5.2
SILINC3R wrote:solid puck-daily driver
You got that backwards.
A full-face clutch is good for daily
A 6-puck is more aggressive, though the unsprung 6-puck in an STi is a GREAT clutch
A 4-puck is totally worthless. There's no reason to use it. Even in a full-out race car a 3 or 4 puck is junk. A pain to drive, and no advantage over any other clutch out there.
We've gone 10.77 on a 6-puck, and 10.80 on an Exedy twin disc.
Posted: Sun Jul 13, 2008 5:51 pm
by 94SS_Canada
So then this is a good clutch to go with?
Posted: Mon Jul 14, 2008 3:35 am
by 93forestpearl
My 6 puck Exedy took a while to get used to, but its nice and grabby. The 9lb flywheel didn't make things easy either.
