Door lock broke,options?
Posted: Fri Sep 26, 2008 2:26 am
by _Aramchek_
So,yeah,what can I do here,is it possible to buy a oem replacement or do I have to find a donor car and then have two different keys or what?
Posted: Fri Sep 26, 2008 2:29 am
Umm....can you be a little more descriptive as to what exactly the problem is?
Does the lock cylinder just spin all around when you put the key in?
If so you can buy a new lock cylinder from the dealer and take it along with your current key to a locksmith to have it rekeyed. If you have a key that is not too badly worn down, that would be best. If you still have the original key that came with the car it will have the key code on it. You can have the dealer cut you a new key based on that key code.
Posted: Fri Sep 26, 2008 3:05 am
by _Aramchek_
Sorry,yeah the lock turns infinately. I still have the original keys,so it sounds like that will work
Posted: Fri Sep 26, 2008 4:08 am
by BSOD2600
Legacy777 wrote:You can have the dealer cut you a new key based on that key code.
They can also cut one from your VIN -- at least it worked with my 94 TW at the dealer.
Posted: Fri Sep 26, 2008 10:24 pm
BSOD2600 wrote:Legacy777 wrote:You can have the dealer cut you a new key based on that key code.
Not all the times. Some dealers especially from the 90 & 91 MY's didn't input the key code into the system Subaru uses to keep tabs on everything. The dealer that had my car did not input this information, however like I mentioned I still had the original keys with the key code stamped in it.
Posted: Wed Oct 01, 2008 2:22 am
by ciper
Find a donor car and take the lock out
Take your lock apart
Swap parts between them
VOILA new lock that fits your old key.
It's extremely easy.
Posted: Wed Oct 01, 2008 1:26 pm
by Bdub
You can get replacement cylinders w/ keys at an auto parts store, if you can't find a donor car.
You can either, A) Use that new cylinder you bought, and swap everything from your old cylinder into it, or B) bring it to a locksmith and have him re-key the new cylinder to your current keys. Just be sure to have both the new and old cylinder with you.
