Cracked Head or Bad headgasket?
Posted: Tue Oct 14, 2008 5:25 pm
Other day when I discovered a crack in my radiator tank I noticed a pool of liquid inside the threaded hole above the upper front corner headbolt on the driver's side head. It smelled more like the degreaser I was using the other day on the engine, and smelt nothing at all like coolant (wasn't even green)
When I shut the car off, the little pool kinda disappeared. Couldn't get the little pool to reappear at all, until yesterday when I replaced the radiator. Didn't bleed the thing right (radiator on this is a PITA to bleed) and was letting it run. Temp needle climbed towards the high side (not overheating), and then I shut it off. Coolant was getting sucked in from the overflow tank after I shut it off.
Again there was a pool of liquid in that hole, couple air bubbles came out of it, then it slowly sank away. After I bleed the air out of the system, temps will not go higher than 1/2 Mark, and no pool will appear in that threaded hole. With it being as hot as it was before it was bled, I don't know if whatever liquid came out of the hole was just boiling causing the bubbles.
I see no white smoke from exhaust, and engine runs pretty well. None of the cooling system hoses are rock hard either. When I replaced the plugs that cylinder had ash deposits on it, but then again why wouldn't it with a plug gap of .065!, and a plugged fuel filter, and who knows how much lack of preventitive maintenance.
I'm going to do a coolant pressure test and a compression test today. IS it common for these heads to develop cracks in them? I'd really hate to have to replace a cylinder head on my Winter car. Coolant system holds pressure. Only thing I could think of is there's a crack in the head in that threaded hole area, allowing liquid to make it's way into the head.. That or the headgasket is compromised and there's a crack in the head causing coolant to escape through that crack.
Engine has 155K on it. 2.2L N/A
