anyway to trace these wires or a pin out diagram would be great. thank you
Really? When my cam (or was it crank?) wires broke while driving from being so brittle INSIDE the damn connector, I went to the junkyard and hacked off 8" of new wiring harness. Then I hacked off my old harness, near where it comes out of the main wiring bundle in the engine bay. I soldered all the wires together, covered with heat shrink, wrapped with electrical tape and plastic conduit.Legacy777 wrote:Those are the crank & cam sensors, and possible knock sensor. They all shielded wiring, and really "shouldn't be spliced due to the low voltages and possibility of adding resistance to the wiring.
