air suspension on Turbos?
Posted: Tue Feb 24, 2009 5:07 pm
by wtdash
Found this
LINK
Scroll down and the dash shows the Height button.
Anyone confirm that this was an option?
I thought it only came on the NA wagons???
Cars101.com confirms that, too, but it's been wrong b4.
This car is FS in the Parts Shed.
Posted: Tue Feb 24, 2009 6:54 pm
I didn't think the turbo's came with air suspension, but if you look closely at the strut top dust caps, they are notched for the wires coming out of the air struts.....so it looks like it's true.
Posted: Fri Feb 27, 2009 4:34 am
by DLC
Posted: Sun Mar 01, 2009 11:22 pm
by entirelyturbo
Interesting. No turbo was supposed to come with air suspension, but Subaru throws in a lot of wildcards for some reason.
Dave, the strut tops on that grey sedan don't have air hoses going into them, so that one must have been swapped as well.
Posted: Sun Mar 15, 2009 8:24 pm
by gijonas
How was the air compressed in that system?
Posted: Mon Mar 16, 2009 5:52 pm
Air compressor. It is mounted under the battery in the fender well.
Posted: Mon Mar 16, 2009 10:20 pm
by gijonas
Sweet! i want.....need that.
Posted: Tue Mar 17, 2009 1:17 am
by Aerotech
It is kinda cool, but the the ride is not what you'd call sporty...
They came with huge swaybars, too, so if you spot one in a wreckers yard, get the swaybars, it's a good cheap upgrade.
The ability to jack up the ride height on command is nice if you do lots of snow or dirt/gravel road driving.
I'm hoping to be able to figure out how to fool the sytem into lowering it all the way... dump all or most of the pressure without activating the compressor to slam it when I want.
Maybe just a switch, wired to cut out the compressor, and also hold open the "lower" solenoid so the pressure escapes?
Posted: Tue Mar 17, 2009 2:18 am
by gijonas
Interesting,that should be pretty easy and work fine.Now i really need this!
Posted: Tue Mar 17, 2009 3:48 am
by entirelyturbo
No you don't.
FAR more trouble than it's worth.
Trust me.
Been there, done that.
Posted: Tue Mar 17, 2009 8:31 am
by asc_up
Agreed. Plus, the airbags tend to go out.
Posted: Wed Mar 18, 2009 11:44 pm
by gijonas
Hmm,my kind of project
