ej22t engine factory compression range
Posted: Thu Jun 11, 2009 11:27 pm
hello,
i've searched the forum as well as come up short using my haynes manual for the factory compression range. i think it's around 180 psi, but i wanted the lower range.
i found one post where a fellow board member was having starting issues and his dry compression was around 140 that climbed to 175-180 on leak down. the board consensus was that the engine was tired.
i've got almost 278k miles on my engine and have a spent valve. my dry compression range was 140-165. i'm trying to see if i can get away with a cheap fix and only do the top end. we're purchasing a house and i need to just keep the car running.
any thoughts? i'll be paying a shadetree mechanic to do the work since i don't have the tools or the space (or the know-how) to pull the engine. any perspectives would be most appreciated.
thanks
thanks
