testing for spark outside engine + more
Posted: Mon Dec 21, 2009 1:09 am
hi guys, so this is the deal:
so my soob is living on 3 cylinders... all but cyl 4 specifically.
i pulled the plugs to verify sparkage and to test compression. The cylinders tested with good results, all compression above 135 and the spark plugs visually showed that they were working bc they are black and show use.
SO.. i pull number 4 and test compression and notice a couple of things.. 1. the spark plug shows no sign of use.. it's seriously like scrubbing bubbles attacked it or something.it's CLEAN...?. 2. there's a wee bit of liquid on it and it smelled like fuel. im almost positive the coil was in and on the spark plug as it's real hard to verify with how hard it is to get them back in.
then after the above i test compression and it flats at 120.. but it does go up to 150 on the first 2 cranks.
so after learning all the above i believe there could be a couple of things wrong.
1. the coilpack (these are coil-on-plug for teh DOHC) is not pushing spark
2. the wires are messed somewhere
so i would like to test for spark outside the car..
On cylinder 2, that i know is working bc of the plug i pulled from it..I have tried touching the threads (on the spark plug) that go into the block on to various things in the engine bay to ground and attempt to get spark outside while cranking the car.. with no results
i did the above as a check to make sure it's not the plug, bc i have tried a couple and also in hope of verifying that my coil #4 is shot.
basically i need help getting my coils, with sparkplug inside them.. to spark outside teh engine so i can verify the coil #4 is shot.. or something else.
thanks for your help,
confusing maybe but i can clarify also
