tps pin out help
Posted: Tue Jan 26, 2010 5:31 pm
by fatgc8
I was wondering if anyone has a pinout of a 91 ss tps sensor. Im doing a swap and that's the only thing keeping me back from starting this thing. Any type of help would be great.
Posted: Tue Jan 26, 2010 8:36 pm
by kleinkid
Maybe this will help you. Someone else will probably have better/more for you.
brown=idle switch 1
black=ground 2
red=power 3
white=signal 4
Please follow up on what you do in regards to the TPS. I may/probably be going to face the same issue.
Posted: Tue Jan 26, 2010 8:59 pm
by fatgc8
Can you tell me what the idle switch 1 does please?
Posted: Tue Jan 26, 2010 9:58 pm
by ericem
Tells the ECU the throttle is closed and to idle?
Posted: Tue Jan 26, 2010 11:26 pm
